killerfish
- Mar 19, 2007
- 19
I broke the hydraulic line that connects to my trim motor for the lift function.
I tried to track it back to where it connects to the outdrive, but can't get to it due to the inboard motor.
Can I access this line from outside the boat?
If I disconnect the portion under the outdrive where the 4 lines that connect to the cylinders are, can I access
the two inner connections that run to the pump?
85 aluminum Startcraft
18.5 ft runabout body style
Mercruser I/O
Alpha One Outdrive
Mercruser I/O
Alpha One Outdrive
