How do you remove the pin from this cable?
E ewpvic Petty Officer 2nd Class Joined Jul 16, 2013 Messages 100 Jun 14, 2014 #1 How do you remove the pin from this cable?
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,356 Jun 14, 2014 #2 Use photobucket.com for the pics
E ewpvic Petty Officer 2nd Class Joined Jul 16, 2013 Messages 100 Jun 14, 2014 #3 Picture can be seen now
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,356 Jun 14, 2014 #4 More likely its a stud pressed into the plate. you navigate the cable end off the stud.
M matth121 Petty Officer 1st Class Joined May 19, 2011 Messages 275 Jun 14, 2014 #5 looks like a rivet to me. would have to be drilled out if thats the case
E ewpvic Petty Officer 2nd Class Joined Jul 16, 2013 Messages 100 Jun 14, 2014 #6 FYI - There is actually a clip in the middle of that pin which keeps it in place
E ewpvic Petty Officer 2nd Class Joined Jul 16, 2013 Messages 100 Jun 14, 2014 #8 I thought that clip would be the first thing I dropped and lost. Install went flawless. Thanks, Bt. I much prefer this old style shift/control to the 80s style Quicksilver. A much sturdier feel.
