Help; can't tilt motor......
projectcop
Hi folks;
New to me 1984 Bayliner with a 1990 yamaha 90 HP elec trim/tilt. After charging battery, put it in and tried to tilt motor down. Heard a "whirring" noise from engine area, but no movement of motor. Same thing using switch on throttle handle or rocker switch on motor.
Ant ideas? I am a newby boater, so maybe I am missing something?
Also, motor will not turn over whili in "up" position. Is this normal? Or again, am I doing something wrong?
Any suggestions would be appreciated.......
projectcop
Re: Help; can't tilt motor......
Anyone? Any suggestions? Did I post this in the wrong forum? ......................
99yam40
I do not believe I have ever heard of a motor being tilted having anything to do with the started not operating, you may need to check to see if you have a bad cable or connection somewhere.
On the tilt motor , I would use a volt meter to see if and were you are loosing voltage. Control circuit or the main power circuit for the T&T motor
projectcop
Hey thanks for the reply; 99yam40;
So now I have something to check this coming weekend. I need to check and see if the battery is putting out enough power to operate the T&T motor and if it is; is there enough voltage getting to the T&T motor. I will need to drop by west marine this week and see if they have the shop manuals for the motor as well as a manual for the boat.
Thanks again for the suggestion.
99yam40
are you sure you did not have the tilt lock in place keeping the motor from going down?
projectcop
99yam40;
Ahha......Tilt lock? Where would it be and what would it look like? I stopped by West Marine today and found a manual for the motor (also picked up a new 20' winch strap). I cannot find anything about a tilt lock anywhere in the manual.
The manual is Seloc #1701 for 1984-1996 Yamaha outboards.
Wow, being in WM was like being a kid in a candy store......took a lot of self control to not just buy one of everything............................
projectcop
cant even find a pic of a tilt lock online. not for this motor anyway. Anyone have a pic, or a link to where there is one?
projectcop
99Yam40;
That is it I do believe!!!! I followed the link you provided and......I remember seeing those (one on each side of bracket). They looked like they were holding something up!! Like I said, I am a newby to boats and outboards!! I waited for my manual and looked there, but it did not say anything about that "tilt support lever" anywhere!!!!
BTW, I have 10 years experience in an automotive machine shop, just have never worked on an outboard before......and did not want to mess up anything by doing the wrong thing....
I do appreciate your input, I do believe you have hit my problem right on the head. I will not have a chance to check it out until sunday, though. I will post and let you know. Thank you again...............
