Re: Help choosing fish locater
Actually the frequency is determine in the head unit or transmitter and not the antenna or transducer. But also understand that ALL depth/fish locators send out a cone shaped signal and receive it back after a period of time to determine depth of anything. But that cone is displayed in a two dimensional screen and not the cone shape (three dimension) it emitted out. So even with a fish (or anything else) displayed on the screen you still have no absolute idea where in that cone the item is located other then the actual depth. So you have to LEARN your system before knowing how it truly works. Look at any depth locater system as a mere tool to assist and not a pin-point system to find fish...
+1
Think of the Transducer as a very selective Speaker and Microphone.
The head unit produces the signal that drives the Transducer.
It is not mix and match. The transducers Frequency must be matched to the head unit.
Actually to make it seem even worse, The transducer transmits a Cone (3D) and the head unit displays the return as a line (1D).
Everything in the cone at the same distance, not necessarily the same Depth, will echo at the same time.
Three small fish at different distances will display as three echos.
Three small fish, one straight down, one to the left and slightly shallower, and one ahead and also slightly shallower will all be at the same distance and will echo simultaneously and display as one larger echo.
As you pass over a hovering fish, it first appears at the edge of the cone and so, slightly farther away, then directly down and slightly closer, and finally leaves the cone, appearing slightly farther away again.
This is why fish appear as arcs and not lines. The arc indicates the depth but tells you nothing about if the echo was to the Left or Right.
Two fish, 7 feet apart at slightly different depths could echo as if one was 3 inches above the other.
There is less information in a sonar display than many think, But it is way better than being blind and seeing nothing.
