I have an 18' center console with a 97 90hp johnson outboard. current prop is a 3 blade turning point 13.25x19. The motor only spins up to 4100rpm and about 29mph.
Im looking to try a 15p prop I believe, but im unsure if I can or should change diameter. Does anybody know what the max diameter I could fit on this motor is?
What are some common prop sizes that would work for me? Other manufacturer hubs that fit as well? I would prefer to find some cheaper used props with hubs already for testing purposes.
Also, does anybody know if I have a 13 or 15 spline shaft? I wont be back with the boat until the weekend and id like to source some props by then
