im new to the forum first post i have a 1979 johnson sea horse 35hp model#35el79a i took it out yesterday first time.just bought the motor.it started just fine ran it at quarter throttle no problems then went full throttle ran fine for 5mins then it started making a clunking sound like once every 30 seconds so i shut it down.then i started the motor again clunking sound got worse every 2 seconds and would not go forward or reverse got it home and draind lower unit and found shavings in oil.i took off the lower unit and pulled the drive shaft and impeller as i look down into the lower the bearings on the bottom are wobblie and move side to side is this normal? also does the drive shaft fit into the fly wheel directly or is there bearings or something up in there.sorry for the long post just trying to give all info i have thank you in advance
