Help...DF60...how do i clear a check engine fault.
Dogfish_magnet
Hi,
I have a DF60 which was giving a check engine error 3 flash's 1 beep 1 flash 1beep,and the engine had a very lumpy tick over (if it did'nt stall), i have solved the idleing problem by cleaning the IAC solinoid and the engine runs and sounds as sweet as a nut but i still get the engine check code...:confused: do i need to reset the ECU or can anyone tell me what the error code is ?
Thanks
JUSTINTIME
Re: Help...DF60...how do i clear a check engine fault.
ecm resets when the problem is fixed
3 flash then 1 flash is a iac bypass setting
u need to set it right
to set it here u go
pinch the iac hose off slowly
remove the rubber cap and turn screw
in= decrease rpm
out= increase rpm
u want 600 rpm
slowly release the hose
best way is the sds program
