Hi everyone i need help.... i thought i had a carb problem,,, As when i started the boat it ran a little rough but then when i add throttle the boat died. I can restart it and same issue.
So i descided to change the spark plugs ,wires, cap rotor and coil. I changed all this and it still seems to run rough. When i add throttle it dies on the hose no load. So then i changed the carb with a brand new unit. The boat seems to run at 2K rpm fires right up seems to run good but on high rpm only. For what ever reason i cant bring down the idle, Seems i cant adjust the idle / fuel mixture on the carb ..with the carb change it runs good at 2K rpm on the hose but every 30 seconds i get a surge from 2K TO 4k rpm AND THEN BACK DOWN. and it runs fine, Any ideas could a spark wire be in a wrong location or the rotor is in the incorrect position ... Im not sure what it could be any assistance would be appreciated ... I belive i got the fire order on the sparks correct. but rotor i wasnt sure on which location to put it in so maybe thats the issue,
Its a 2003 Mercury 5.0 L carb motor. 2 bbl rochester
