help engine water in oil
272boat
hey need some help please , ran a 272 boat, formula twin 350 the one engine i noticed after running it for 20 mins It was leaking oil, out valve cover all oil ever were it was a few qts in the engine floor, boat hull. brought it home added oil and fixed valve cover, started up and ran seems to run ruff ruff start but has good compression, didnt test it yet but seems to run ok and starts reves up,,,, oil has a littl milky why even if it was run oil low the water pump was pumping and engine showed no sign of over heating help help milky oil but not full like the same amount of oil on the dip stick it stays the same dose not go up like more water ... help
272boat
Re: help engine water in oil
I sucked the oil out through the dip stick (with a air pump out machine) and pulled out 6 QTs,,,, i only added 3QTS when i realized it was low so my understanding is it only lost 3 qts i do not know , i still have milkey oil just a little , ,
Ayuh,.... Welcome Aboard,.... You've got me Confused,....
Is it leakin' oil or not,..??
If the oil is milkin' up, is the level risin' at the same time,..??
Who's motors,..?? 'n What drives,..??
xanthras
I am no expert on engines, but wouldnt that mean that your head gasket is bad? Water from the cooling jacket is getting into your oil system and overflowing it. Somone with more knowledge should probably be able to explain better.
