Help!!! Engine water leak!
tcooke
I have a 1965 Mercruiser 110Hp inline 4 cyl, just started it up after rebuilding the rest of the boat and it spews out water from under the exhaust manifold. It looks to me that there 3 pieces to the manifold, the manifold itself and 2 lower plates about 3/4" thick each, the leak it coming from the bottom plate through a crack but what part is this? can it be replaced or does the entire Manifold need to be replaced?
Thanks in advance.
Re: Help!!! Engine water leak!
Ayuh,....
Is that the GM motor, or the Renault motor,..??
