craigstuff72
- May 5, 2008
- 5
I need some help in a bad way from you experienced boat wrenchers. I just picked up a boat with a 91 200XP Evinrude--it wasn't shooting water so I changed the impeller-key is in right- and still no water. Blew out everything with air...still no water. took lower unit off again and attached hose to water tube with motor running...still no water. The water manifold is holding alot of water but nothing is coming out the tell. Water is coming out the fins in the bottom of the lower unit and it is pretty hot. The heads are getting pretty hot too. You can keep your hand on em for a couple seconds at most. If the cooling passages in the heads are clogged---is there a good way to unclog them? any other ideas? I didn't see a tstat on this either--just a pop-off valve I think it is. Thanks for any help--Jeff
