Help fixing bouncing tach
gazkid
Have a Volvo 3.0 GS Tach is steady up to about 3800 and then starts bouncing above that. What should I check first. I'm guessing it's not the tach unit itself seeing as its solid uo to 3800. Thanks!
biggziff
Re: Help fixing bouncing tach
Mine was doing that until I made sure all the plug wires were not touching along their length. I bought some plug wire keepers at Napa for $3 which solved my problem.
gazkid
Thanks. I'll try that. Makes sense because the more I thought about it the more I'm convinced the tach was over reading the actual rpm and that the tach itself is ok.
biggziff
Also...if your tach is reading too high just give it a few smacks...I read that trick here and it worked great for mine.
