Re: Help foamy oil.
After it sits for a few days crack the bottom seal and ease it out to the point that you can bleed a little fluid out if it. Any water? (My bet is yes.)
If its not a lot live with it for the summer. Check it and change it a few times over the summer and do a tear down in winter. You can usually talk your local boat mechanic down on price over the winter while they are hungry.
Good time to do water pump too since you have to go that far to get at the seals.
Don't forget to check and change you tilt cavity oil often. Water all ways get in there no matter what. water floats the oil up the shaft and in to the motor.
This oil dissolves the lacquer insulation on the motor windings and poof no more motor.
Solution, check and change every time or 2 out. Or if you keep boat in slip every time you take it out for whatever reason.
