Re: Help from a JVC VCR technician Please!!
There are LED sensors in there that detect end of tape etc. and it is possible that a transmitter or receiver is bad.You used to be able to buy them by the set at Radio Shack but basically they are both an LED and you can test them the same as you would any LED.
Another item would be a mode switch that has failed depending on the particular tape deck that you are working on.You cannot tell by the brand name who really made the thing,Funai makes the bulk of them it seems these days.
I will give you a link to a website that has free schematics and you may find something close enough to yours to troubleshoot it if not the exact one you need.Most of these schematics are broken into smaller files that will require multiple downloads,each file is usually 1.9mb for the dialup guys.
Download IZarc to decompress the .rar files after you have downloaded all the separate portions of the file.It sounds like a lot of work but it really is not and the benefits are having a schematic that you can use to make your work easier.
I also upload schematics to this site when I have to buy one occasionally but this site is a goldmine and has bailed me out more times than I can count.Good Luck.Ron G
http://fileshare.eshop.bg/
