Help - fuel pump
mjestey
I reconnected the fuel pump wires and it still doesn't like starting, but when you get it started it runs great, but has a top end of 27kph. Does that mean that the fuel pump is bad? Why would it run when the fuel pump is disconnected? Any thoughts much appreciated.<br /><br />Mike :confused:
rolmops
Re: Help - fuel pump
Hello.<br />Most fuel pumps run on the vacuum off one of your cylinders and the wires are there for other reasons but not knowing your engine type i dont know what these functions are.
12Footer
what rolmops said. Most run off engine compression if they are outboard. Inboards and I/O's have cam-driven or electric.<br />But check the filters first, and the tank for water.
