steelhorse1369
- Aug 27, 2016
- 9
97 johnson still wont run!!!!!!!
After many hours I guess im stumped I have been around boats all my life have never found a motor i couldnt make run. This is a 97 Johnson 40 hp, only had it about a year dont know the history of the motor. its on a pontoon was running fine and lost power at full throttle went down to near idle ,it was immediately turned off and checked ,it was not overheated all looked good. When tried to restart it fired and died would not stay running. First thing you think fuel issue, it had a vro pump with the oil line cut and plugged with a bolt, didnt like that to start with so I started there, converted to a standard pulse pump mounted on on the block, pulse for the vro was properly plugged at the motor,fuel and vacuum lines all replaced, still same result so I still thought has to be fuel, noticed fuel dripping from front of the carbs, got carb kit and cleaned /rebuilt carbs reset floats set idle screws at 1.5 turns from soft seat,drained fuel supply line and fule lines drained carbs hooked up new tank of marine fuel,,, same result fires and dies.Replaced primer bulb and supply line and connections,same thing fires and dies ,pulled carbs back off checked my work and checked reed valves all ok, same thing, still has to be fuel delivery. Took carbs back off took to a friend that dose marine work he checked carbs, sprayed gas into carbs while trying to start flooded out would not fire pulled the plugs all wet, thinking now it could be electrical, checked spark, bolth plugs fireing consistently but not bright blue , checked to make sure pistions were top dead center with marks on fly wheel and are, compression check 130 top 115 bottom ,not great but should not effect the motor from running. Replaced plug wires and spark plugs,yep same sh?t , next new coil , yep no change , IM stumped what am i missing, may be next replace power pack. I just dont get it i must be missing some stupid little thing . THIS IS DRIVING ME NUTS!!! ANY IDEAS THANKS , ?MARK?
