HELP! How do you install the fitting on the Nylon trim hose? PIC
Friscoboater
I have been banging my head on the wall on this for about two hours. My nylon trim hose has a leak and I am trying to replace it. The little brass ferrule looks to be smaller than the hose (see picture) and I cannot get it on the new hose (which is the exact same size). Is there a trick to this? I tried cutting the tube at an angle... nothing. I tried pinching the end... nothing. I tried lube... nothing.
These stupid little details are really starting to make me tired of this project.
Here is a picture of the old tubing with the ferrule still installed. Anyone know a trick?
a70eliminator
Re: HELP! How do you install the fitting on the Nylon trim hose? PIC
Easy answer, the ferrels are for one time use only, your ferrel has already been pinched down, it's simple you need a new one, looks like 3/8 and any hardware store should have them in the plumbing dept.
Ayuh,... Exactly,...
Juniinc
deformed circle ring whenever they are pinched down.
Being a plumber, we deal with this a lot. Yes a new piece would be nice,,,
if not, with some soup put the outter nut behind that ring then tap it in.
Friscoboater
Ahhhhhhhhhhhh. Thanks alot guys. I love this place!
