Re: Help! How to trim/tilt OMC Stringer, Part II
Yep, in general a 21" will give you a bit more top speed and less acceleration than a 19", and ~400 less RPM at WOT. There are way too many variables to say for sure, you need to talk to your local prop guy. A SS prop will usually give you up to 5-10% better performance over aluminum of the same dia/pitch, both top speed and acceleration.<br /><br />I've never really bought into the idea of using aluminum to minimize damage; as a previous poster said, if you hit a rock or whatever hard enough, you're gonna break something in the lower unit, no matter if you have aluminum, stainless, or titanium! In theory, the hub will spin (Thats the rubber bushing around the hub of the prop) and prevent damage. Sometimes does, sometimes doesn't. The advantage of a SS prop is that it will survive hits that would really tear up an aluminum prop.<br /><br />The trim tab that I am familliar with is that little 'fin' that hangs down from the anti-cavitation plate, in front of the prop. You can loosen it (2 bolts if I remember correctly) and adjust it's left-right angle. This is used to compensate for p-torque, the force applied by the prop spinning in one direction. If it's out of adjustment, the boat will be really easy to turn in one direction, and really hard to turn in the other. The catch is, this force varies with how fast you are going, so the trick with the trim tab is to find a happy medium.<br /><br />The guy talking about trim tabs may have been talking about something else...<br /><br />Tom
