AntelopeWI
- May 2, 2010
- 11
Hello everyone,
I just got a boat with a 1973 Mercury 1150 Thunderbolt on it. 115 hp.
I was told, "the engine needs some work." Whatever that means.
I would like some guidance on how to go about checking this thing out and getting it going again. I have never worked on a boat motor before, but have worked with other small engines and am pretty handy so I am looking forward to this challenge. I have the seloc manual for it.
I would love some experienced advice on the steps I should take and in what order. I figure I should replace the water pump, check compression, overhaul the carbs, maybe do the fuel pump. You will see in the pics that the distributor is disconnected. Do I need to get that back on before testing compression? Don't want to burn anything out by doing things in the wrong order.
Can you guys take a look at these pictures and give me some advice on where to start. Sorry for all the pics, but I know it is hard to give any advice without seeing what I'm working with.
Here you can see the distributer is off. The ring to couple it together came with the boat.
THis cable was laying on the bottom of the engine under the distributor. Not sure where it goes. Thought maybe it was a ground for the distributor or something?
Sparkplug wires taped up
