Help ID Force 70hp year model
bigjoe1907
I just bought a Sweetwater pontoon with this engine, but don't know what year the motor is Serial # 0E009962.
roscoe
Re: Help ID Force 70hp year model
HI there bigjoe.
You have a 1991 model.
bigjoe1907
Thanks Roscoe,
How can you tell what year it is by the serial #? Is there a number system or what?
roscoe
No system really.
They just use consecutive numbers.
Then continue on from where they left off for the next year.
ncsteelman
I have the same issue. Supposedly mine is a 1995 model 70HP. Serial # OE10815?
tmclaren
What serial number > year reference are you using? Is there also a reference to model number? I have a book that's dated 1994 and an engine with serial number OE162385.
I'm also looking for a new lower unit. Seal failed, lost gear lube, cooked gears and snap crank shaft. :(
roscoe
Using the serial numbers that are listed in the parts catalog, that is year specific.
Serial numbers 0E138600 THRU 0E202999 were used in 1996
Sorry for your engine problems.
And welcome to iboats.
