Help identify outdrive
knotperfect
My outdrive doesn't seem to match my ginbal housing. The gimbal housing has the trim sensors on both port and starboard side. The drive itself has the eye hook on top. What do I have?
knotperfect
Re: Help identify outdrive
Don.... Bummer, but the links not opening up. I looked earlier and thought MC-1 but was later told Alpha since the gimbal has the trim sensors on both sides.....
Ayuh,... It's a later model MC-1...
knotperfect
So when I order parts, water pump, for instance. Some listings state MC-1, others state pre-alpha. Are these essentially the same for items such as bellows, shift cables, water pump, etc? Thanks for the help.
