Engine is 1999 5.0 Mercruiser and Outdrive is an Alpha One, Gen. 2. I need help identifying the part identified by the red arrow in the attached picture. It is a hard rubber (maybe even plastic) part just forward of the shift rod/gear selector rod. For refererenc, in one of the pictures, you can see the hole in the Upper Gear Case where the drive shaft from the Lower Drive Unit goes into. This hard rubber piece looks like it's out of place and I is damaged (possibly from the movement of the shift rod). I have checked many diagrams of the outdrive unit and was not able to pinpoint this part.
