Help Identifying a Johnson Outboard
realboats
Hi. I have what is supposedly a 1989 Johnson 130hp motor. The model number stamped on the engine is J130TX-CEM. The serial number is on the Bill of Sale which I'm trying to find at this point. I haven't been able to locate the serial number on the motor The outboard was purchased from a small, one-man outboard shop near Boston.<br /><br />The problem is, I cannot find any information on 130hp built in 1989. Here is what I do know:<br />*It's a twin power pack(CDI?)ignition. The number on the power pack is CD4 583110 OA11U13<br />*It uses the larger VRO pump mounted toward the front, port side of the engine<br />*The cowling actually looks like a mid 90's model. It uses the red plug to wire into the motor.<br />*The terminal strip is only a five connection point. (not counting the two mounting screws)<br /><br />I've been pouring over my aftermarket manuals and wiring diagrams and nothing matches up to a 130hp. This motor is definitely larger than a 90hp.<br /><br />Could this be some beast put together from a bunch of spare parts? It runs fine, at least so far but I haven't put it through its paces yet.<br /><br />Any information you can offer will be greatly appreciated. I've spent hours trying to ID this thing with no luck. The info I have only goes to 1990, but I would be very surprised if it was a later model than that.<br /><br />If you prefer to respond by email, please send to realboats@aol.com I can send pictures of the power head of anyone would like to take a look at it.<br /><br />Thanks,<br />Dennis
Hooty
Re: Help Identifying a Johnson Outboard
The model number is definitely for a 1989 130hp Johnson. The "130" iz horsepower and the "CE" is 1989 (C=8, E=9).<br /><br />c/6<br />Hooty
realboats
Thanks Hooty. Nobody seems to have a record of this "mystery engine" being made, not even the dealers. <br /><br />I guess it's not a real big deal, though, as I've found the same OMC parts are used across so many different models that getting parts shouldn't be an issue. Even troubleshooting shouldn't be a problem for the same reason.<br /><br />Regards,<br />Dennis
Dhadley
1989 V4 loopers were 120 and 140 hp. They used a single powerpack mounted at the top center of the block and to the rear kinda under the flywheel.<br /><br />130's were first built around 1995.<br /><br />There should be a tab on the head gasket at the top of the head. Is that tab straight across or have a notch in it?
Dhadley
Are you sure this is even a looper?<br /><br />Even the older loopers had only one pack. Crossflows had 2.
spitter
Hellow. I have a vintage Johnson Super Sea-Horse 50, MOD # V4SL-11 Ser # 1833003. I'm unsure of the year. Can anyone help me please. Thank you.
kenmyfam
Another 5 year old thread back to life !!!!
