Hi.
Im in Australia and picked up a DT140 inline 4 cyl.
The only problem is i cant work out the year or exact model number.
Ive puled it down as its done a bearing that's why i got cheap and want to fully rebuild it as ive done with a yammy a bit back.
The only stamping i can find is the SN tag
exactly as it reads.
printed "4002" Stamped next to it "201556"
i want to oder a full gasket kit, rings, pump, trim motor etc but dont want to order the right things. I know whit the yammy most the parts was from 2 years before and 4 years after, not sure if this is the same case?
thanks in advance.
thanks in advance.
