Help identifying engine and impeller
PeteB_2000
Hiya,
Im a boating noob, bought a speedboat less than a week ago, and now engine dont work, seller told me to flush motor with clean water after using it only said to make sure prop was submerged, yes you guessed it I burnt the impeller out, Ive managed to locate and remove the impeller, but can someone tell me the make model and year of my engine along with which impeller I need.
The only info I have is the engine serial number which is
15036B R2384
Cheers
Pete
lark2004
Re: Help identifying engine and impeller
1962 18hp?
that's what I get for 15036B
Assuming that you have an older Evinrude.
But if it's another make, Yamaha or Mercury etc...... then who knows....
PeteB_2000
great yeah its an evinrude, can someone point me to someone who will be able to supply an impeller, ideally in the uk
Pete
