Help identifying Mercruiser outdrive
poxxx
Hello, im from Argentina, im looking for the repair kits for a mercruiser sterndrive from an old motorboat I´ve just bought and started restoring.
I´m having troubles to identify the model to buy the correct items. I think it is Alpha one gen I but no sure and dont want to order incorrects items.
Here are some pictures may be you can help me.
Thanks in advance.
Ayuh,...... Welcome Aboard,...... That sure looks like an Alpha 1 to me,......
A tad rough, but ya, an Alpha 1,.....
achris
More fish than mountain goat
The transom assembly is a very early MC-1, the drive could be R, MR or Alpha One. The only way to tell between R and MR/Alpha One is to split the drive and look at the top of the drive shaft. If it has a spring-loaded pin, then it's an R. If no pin, then MR/Alpha One.
Chris............
(MR and Alpha One are the same. Just different years)
