Help Identifying OMC E2951285
pvanv
I have an old apparently 2-stroke 1-cylinder OMC outboard. It has only wind-it-around rope start (no recoil), a small integral metal fuel tank. U-shaped plastic cowl/cover that attaches both to the carb and the tank mount. Start-in-gear type, and a flat bar tiller handle (broken off). I would like to identify it The frost plug has number E2951285. The wee motor is very light (maybe 20 pounds). No visible model label of any kind. Thanks!
First year of that was 1968.----1.5 HP------after a few years they added recoil starter bumped it to 2 HP.----Post a picture.
F_R
Serial number places it at 1968 or 1969. Probably 1968.
pvanv
OK, so it's a 1-1/2 hp motor. What model number do I use when buying parts? Looks like I need to seal the tank with antique auto tank sealer, and I haven't gotten it to fire yet. I suppose it has points/condenser, since I don't see a CD box.
flyingscott
Yes you have points and condensors. Go on Evinrudes website and go into there parts dodge it goes back to 1968.
F_R
1968 Evinrude 1-1/2hp model number is 1802.
