PensacolaJason
- Oct 23, 2011
- 176
My choke stopped working on my outboard and I believe I have identified the part that appears to have stopped working. I believe I am looking at the part referred to as the fuel primer solenoid. As best I can tell when the key is pressed in on the ignition, the plunger on this part is pulled in which tugs on a metal wire that is attached to a reed valve that chokes the motor.
When I push the key in this part no longer works and the reed valves do not move, so I am assuming this part is defective and needs to be replaced. My issue is that when I look up my motor parts I am unable to find a match. The closest thing I can find it this part (5007356). The problem is that this doesn't look like the one I have on my boat. It is specifically missing the plunger that goes in and out and pulls on the reed lever on the carb, so I am confused as to whether this is the part I need and, if so, how this part replaces the original. Any help would be appreciated.
My motor is a 1983 Johnson 50hp (J50BELCTA). Here is a picture of the current part which isn't working any longer.
