Help identifying SternDrive- Volvo? LOTS OF PICS
Jaheim
Hello all,
this is my first post in attempts to identify my sterndrive. Its attached to a Volvo Penta 570 sitting in a 1990 Carver Montego 2357 Mid cabin.
1)Which drive do I have
2) On the left (passenger) I have a spring that's just hanging there. What is it? on the driver side there looks like a spot where there should be a spring but none present???
3) it's hard to see in the pics but there are two sets of wire ropes with binders around the drive. Looks like they are there to hold it on in case it separates???? I've never had a boat with this on it...
Thank you all in advance and sorry for cruddy pics.
http://smg.photobucket.com/albums/v365/ks_stickbow/Carver/
Don S
Re: Help identifying SternDrive- Volvo? LOTS OF PICS
Easiest way to ID the drive is look at the model/serial number plate on the drive.
attachment.php
Jaheim
Thanks Don, but I have a small corrosion problem which is preventing me from seeing these numbers. Any chance of identifying this from the pictures?
captmello
It's hard to see what you've got. If it has the old retaining pawl, which I believe is where the springs your talking about should be, it's probably a dp-a. I believe the dp-c had done away with the retaining pawl. And if the springs on the Pawl are broken, then the outdrive would kick up when in reverse which is why the previous owner may have strapped the outdrive down.
Thats my guess anyway. Welcome to Iboats, BTW.
Jaheim
captmello,
You are correct, I just spoke with the old man that wrapped those darn wire ropes around the drive. He said he did this because the drive was kicking up in reverse, and stated the OMC rep told him that's a quick fix. So yes, looks like I need new springs.....Looks like Iboats sells it....http://www.iboats.com/Volvo-Penta-Revers-Tilt-Lock-Springs/dm/*******.774554877--view_id.269443
I was out there looking around and and spraying penatrating oil on things, and the hooks work free, I just don't understand what they hook on to.
There seems to be alot of talk on the net and here about the reverse lock, but I cannot find a nice diagram that will show the mechanism.
Any chance some one could point me to a drawing until I can find out what drive I have and get a book.
Thank for all you help. I am a newbie to sterndrives, but I have a feeling I'll be a pro by the end of summer.
captmello
Jaheim
The trim works just fine....There is a little lock on the side controls that's a bit tricky but all in all the trim work good.
Jaheim
In the diagram #59 and #62 serve the same function? Both locking hooks? what do they actually hook on to? Will they only hook onto it when shifted into reverse?
captmello
they should be hooked to a crossbar of some sort. Sorry but i don't have the same outdrive.
Jaheim
No problem you've been a great help....I found two little pins that the hooks hook onto. I was able to break loose the nuts holding the hook on and will clean it up. If I tighten the nuts down the hooks no longer move....
captmello
the hooks are spring loaded so that if you hit an underwater object, your outdrive will release.
Jaheim
I've ordered a sprint kit already but just a thought. If I tighten the nuts on the hooks in a permanently locked position.....will I just loose the swing away feature or will there be other problems?
captmello
I prefer to fix things properly if possible. the springs are easy to install.
BTW, what is all over your outdrive? Is it growth? Corrosion? But the lower is pretty clean, why?
Jaheim
It looks like years and years of painting and repainting...I power washed it quickly, and that's what is left. I started scrubbing and repainting....that's why the bottom looks better then the top...
today I found a manual tucked in behind once of the draws...it's the manual for the outdrive...the previous owner has 570/DP circled as being the outdrive....I though the 570 was the motor and DP was Dual Prop...so is this not a DP-A or is a 570/DP-A?....
VP has a wacky naming convention
captmello
570 is the engine model number. It refers to a 5.7 ltr (350). DP-A is the outdrive model name.
