Help impeller replacement
midnightrider1818
Ok got my new impeller in the housing and dumb me turned the shaft without it bolted down and it popped out now I can't remember which way the fins were suppose to point. I think I have it right. With the housing flipped over I have all the fins pointing in a clockwise direction. Is this correct. Also I do not see any seals in the tube off the pump. This is a old r model drive pre alpha. Is this drive supposed to have o rings in there
Bt Doctur
Another way to look at it if you install the impeller in the housing by hand , push down and turn it to the left. this will have the fins going top the right, clockwise.
There is a rubber seal in the top of the pump housing to accept the copper water tube. The plastic guide tube just pushes in the top of the housing
Woodonglass
A picture is worth a thousand words....
alldodge
Even though that isn't the same housing it's opposite of what he needs to do
midnightrider1818
Ok got the impeller in right but I do not see a seal on the pump housing nor did my kit come with one. I just have the big fat or ring that goes over the shaft down onto the pump housing. Anybody have a pic of this seal. Unless that seal is for the tube. Again this a old r drive
Bt Doctur
http://www.boatfix.com/merc/Servmanl/6/6B3R3.PDF
see page 3B-8
28,29,30 gaskets,
33 rubber bushing the copper tube goes into
42 plastic guide tube the copper tube goes in to find its way into the pump body
41 thick rubber slinger washer goes on top of the pump body on the driveshaft
