I'm installing a Rev 4 prop on 2007 E-Tec 200hp satwater model. I'm using a flo-torque II adapter. No matter what I do (config parts supplied with flo-torque II prop wobbels (by hand movement) at the end next to the thrust washer. It appears that the splined shaft on the motors lower unit extends about 1/4" beyond the flo-torque II splined hub so even if you tighten the prop nut, prop still wobbles. It seems like there should be a bushing in the plastic sleeve at the end next to the thrust washer.
SURE COULD USE SOME HELP OR INFO.
Thanks.
Thanks.
