gowestwardho
- Jun 17, 2009
- 6
I have a 5.7 Liter EFI with a Volvo/Penta I/O. When I first launch the boat - or when I start up after being at anchor a while - the power trim/tilt gauge is not reading and the needle sometimes bounces around up and down. Once I get underway however it usually settles down and gives an accurate reading. Also sometimes I can 'kick' it into reading properly by trimming all the way up or down to the stops and then it seems to be OK until the nest time I sit at anchor a while. It does not do this all the time however (in other words it doesn't happen each-and-every time I start up from rest). Any ideas what I could check? The trim/tilt otherwise works fine as does the gauge reading once it kicks in.
