Re: help johnson150 crossflow what is the operating water temp?
The above temps (140-155) are when idling. The head temps will go down dramatically when on plane. The pressure relief valves will open in the thermostat housing, flooding the block with extra cooling water. Your temps could go down well below 140 when planing, esp if running in cold water. The overheat horn comes on at 212 degrees, and will silence when the heads get back down to 175 which is still considered too hot, for normal operation.
