Fiberformboatowner
- Mar 11, 2013
- 41
So I pulled both drain bolts and to my surprise the oil came out very slow and it was a greenish brown color is my lower unit ruined?
In this situation, I'd suggest you get a couple of sets of crush washers ($1 each.)
Then change the lower unit oil and run it awhile in your boat.
Then take your lower unit to a qualified marine mechanic or dealership for a pressure test and a vacuum test. They'll have to drain it to do the test. Have them assess the condition of the lower unit. Only then can you be assured that your lower unit is not going to take in water.
Nothing worse than burning up a lower unit. The penalty for not changing the fluids is over $2K for a new l/u. Used lower units also pull a big price on the retail market if in good condition.
