Mcdaniel1991
- May 8, 2016
- 26
I'll start with the pictures,
OK now that you have familiarized yourself with my boat here are the problems. We purchased this boat just as you see it for $400. I now have about $1000 total in it from a new gimble bearing and bellows kit, a few special tools, and registration fees.
I have discovered that the engine is getting water in it some where, have done a compression test and got in order 120,110,110,95. My next step was to pressure test the block to see if it's a crack.
The floor appears to be in good shape. It has only 2 soft spots one forward and one rear of the center storage. In the pictures below the anchor is setting on the soft spots.
It appears that the rest of the floor is solid.
The outdrive appears to be in good shape, the oil looks decent and the few times I have had the boat out I have heard no noise from it. In the video below you can hear and see the engine running, I think the noise is from a bad engine coupler.
Now my delima is, should I put the money into this boat to get it running right? What should be my stopping point as far as what this thing is worth. I'm not attached to it by any means. Just trying to capitalize on what I thought to be a good deal at the time.
