MadPikAvenger
- May 29, 2012
- 17
Greetings all,
So I have a 1995 Bayliner 1750 with the 3.0L Mercruiser (serial #0F287053) that I've been having issues with water getting into the oil. No visible leaks on the outside of the engine. I checked the compression and got the following results:
Cylinder 1 (front of boat): 170
Cylinder 2: 170
Cylinder 3: 170
Cylinder 4 (rear of boat): 60
I put some oil in the 4th cylinder and the pressure rose to about 80 one time and on another test a couple days later jumped to about 120 but was less and less with each test.
I realize I probably should have pressure tested the cooling system and all that but I was too excited to start taking stuff apart that I pulled the head and manifold hoping to find some obvious (to me) problem. Of course I didn't so I'm hoping all the great knowledge and experience you guys posses might be able to help me out.
Here's what I did find. The exhaust manifold only appears slightly corroded in the passage that the water goes through and not anywhere else. The riser looks a little corroded in both passages (not sure if that is normal)
Also there was obvious oil on the exterior of the engine near the 4th cylinder. I attributed this to oil/water getting blowing up through the "vent" in the valve cover. It can be seen here:
Here's some pics with the head off:
Here's how the valves/gasket looks (4th cylinder is on the left):
I put some gas in the 4th cylinder with the head upside down and it appears it leaked past the valves:
And finally I noticed that the head gasket was firmly stuck to the all the way around except near the 4th cylinder near where I observed the oil on the exterior. In this area it looked like this:
I haven't checked to see if the head is warped at all yet but is the condition of the gasket in that area a sign that it wasn't sealing properly?
So my big question is what does this all mean and what could the source of water in my oil be? If any more pictures are required just ask.
Thanks!
Cylinder 2: 170
Cylinder 3: 170
Thanks!
