I have a tach connector on my mercontrol <br /><br />And it has 1 plug in it which is the tach sensor and the other 2 are postive and negative for use with console stuff that needs electricity. My Tacho is a Stewart Warner (SW) tacho which just has a red bolt and nut and black bolt and not on the back how do i hook it up to the tach connector like where do i put the tach sensor cable. <br /><br />Also do you tihnk a 4.4m runabout (de hallivand 1974) with a 65hp Mercury thunderbolt 1970 motor could pull a water skiier?<br /><br />Thanks
