Re: help me i need help with my mercury 50 1979
Mix up a spray bottle of pre-mix and try to start the motor while shooting some pre-mix into the carb throats. If it fires, you most likely need to rebuild the carbs or at the very least, get new hoses from the tank, including the primer bulb. You are pumping up the primer bulb first and using the choke when you try to start it, right?? Has the motor been sitting for a while? More info, please.
