MrsFish
- Apr 14, 2009
- 6
Okay so the issue is a severely bogged down motor. I have had the thing running great one minute, then next time I start it it's a dog. Compression is 76 in 3 and 74 in the cylinder needing an insert. I have yet to check for "consistant" spark cause I had to helicoil one of the plugs (maybe this will solve the problem but I doubt it). Since I had the cylinder cover off the one side I figued may as well clean and re-gasket both sides. Pistons and cyls look good but alot of carbon. Anyway I suspect the following things are problems... First I have a water choke assembly?!?, choke never closes. Second it appears that somebody changed out a venturi once upon a time and the #'s do not match. I would like to know how the venturis are supposed to behave? One of them is a slow drip and the other is about 5x faster of a drip, almost a stream. I eat fuel like you would not believe but I have no frame of refrence since this is my first boat. 1964 16' Glastron Skiflite.
