HELP ME PLEASE!!! 1978 Mer will not spark but i have good power to new coil
I have 78 mer 140 i have tried everything i can think of, i changed the....
battery
coil
plugs
wires
cap
points
i am getting good power to both sides of the coil and i am still not getting a spark!!! i have tried everything i can think of. please help me, also the boat cranks over fine but just no spark
RaScLeS
Re: HELP ME PLEASE!!! 1978 Mer will not spark but i have good power to new coil
mostly powerpack issues affecting these motors. is it not sparking on all cylinders ? or some ?
its not sparking on any of the cylinders
and what do you mean by powerpack issues is that something i can change all together?
blackbox
i had more problems with the triggers(distributor housings) back in the 1980s, than any other ign. part. you may be able to find a used ign. system from a parts motor, lots of old in-line 6 motors in bone yards.
good luck!
Chris1956
First of all a 1978 Merc 1400 does not have points. Also, one side of the coil is grounded, and the coil is pulsed by the switchbox, to induce a spark. There is no way to have power on both sides of the coil.
It also uses a hall effect sensor in the distributor. There is a test for the battery-powered CDI ign system on this site as well as the CDI Electronics web site.
You might post the serial number, so we can figure out what you have.
JustJason
is this a sterndrive? if so... you posted in the wrong section.
chris1956 the serial number is 5458529
model is MCM 140
and as far as the coil + and - i checked and thereis running power from both sides
as far as the cap and points i pulled the cap and when i turn it over i can see the points working and the cap spinning, everything looks good but still....no fire
sschefer
Do you think it's possible that someone tried to convert this distributor at some point. The parts diagram doesn't show any points but it does show a switchbox.
bclery
Sorry if this is a dumb idea, but..
There is probably a kill line from the switch box to the ignition key. Have you disconnected that or made sure it is not shorted to ground?
Is there any kind of rev limiter on that model? Did you disconnect that ?
Laddies
Banned
MCM 140 is a chevy 181 cu.in engine not a outboard.
sschefer
Well I'll be danged. No wonder it won't start.
thak you guys awesome help it is running now!! but new problem i am going to post it.
