I've tried some different props and I'm hoping someone can help me with the results:
1979 johnny 115 on a 1980 skeeter wrangler (semi V) approx 1200lbs
I have tried two props. Both from the same era as the motor, both SS and in good shape. Motor is recently rebuilt and running great. Cav. Plate is 1" above the bottom of the boat
1st one:
13 3/8 X 17
44.2 mph (GPS) @ 6200 with trim
and
13 X19 X 19
46.5 mph (GPS) @ 5600 with trim
pic of motor height:
I'd like to get to somewhere between that. Is there a modern day prop that you would reccomend to get me where I need to be. is a 600 rpm drop correct? Thank you for your help as always.
1st one:
13 3/8 X 17
and
13 X19 X 19
