help merc 50 1979
rickdb1boat
Re: help merc 50 1979
bentley <br /><br />With limited information, are you getting fuel to the engine? Did it sit for a long time? Try putting some pre-mix(50:1) in a spray bottle and shoot some into the carb throats and see if it acts like it wants to start. If so, your carbs are probably clogged up and due for a rebuild and cleaning. Does the primer bulb pump up firm? Fresh gas? Choke on? More info, please.
99jf2
it has been sitting for a while what else could it be?
rickdb1boat
Did you try what I suggested? And are all the other parts in working order? Carbs rebuilt?
