Re: HELP my johnson 110 driving me nuts
Does the primer bulb get firm when squeezed (before starting the engine)? If it doesn't, the float level in one or more of the carbs is misadjusted which prevents the inlet needle and seat from closing off the flow of fuel. You also did not indicate year and/or model number of your engine. Spraying carb cleaner in the throat cleans only the throat -- it does absolutely nothing for the internal carb passages.
