Took my wife out for a fast run around the resevoir. I have a 1981 wellcraft inboard with a cuddy cabin I bought saturday. Last night was my second trip out. I got launched, pulled away from the ramp. Putting it in gear, it went slowly, but giving it the gas only resulted in us going a few knots and making alot of noise! I made a loop and pulled the boat back out quickly. After coming up the ramp and inspecting I found the castle nut on the prop shaft spun up (wire, pin thing that WAS holding it gone), and the impeller very loose on the shaft. What is the correct way to reinstall this thing? I can push the impeller onto the shaft (should I grease it?). Next on goes a thick washer that is grooved to fit the impeller shaft, then the castle nut. Will a regular large cotter pin be ok to hold the castle nut on? If not I will send my wife to Smith Marine for the proper pin(s) today. You guys think I damaged anything somehow? I appreciate the help, I'm new to boating. I have owned a 2 stroke jetski for the past three years, so I'm used to "Wrenching"......
