prc03sx195
- Nov 3, 2007
- 153
I put in a new teleflex rack cable SSC15415 and now when I turn the wheel right the boat goes left and when I turn the boat left it goes right. What did I do wrong? Does it have anything to do with the helm pinion position when you bolt on the rack? What if I turn the helm 180 deg, will that make it back to normal? Does the helm shaft need to be in a specific position? I am baffled since I think I have it installed the same way as it was before I took it apart.
This is a single cable rack and pinion steering and I just replaced the cable.
paul
paul
