Help. My Yamaha 50 Motor is Not Getting Power???
hogsnapper
Are there fuses on the motor which controls the power getting to the motor? I know its not the battery because i made sure it was completely charged and also my fish finder works along with the lights and other electrical equipment. But nothing having to do with the motor works. No trim/tilt nor does the motor try to crank. Any help would be greatly appriciated. Thanks in advance.
bgbass.1
Re: Help. My Yamaha 50 Motor is Not Getting Power???
there is a 20 amp fuse if looking from rear left side
hogsnapper
Thanks for the respone bgbass. Is this a standard 20 amp fuse? Also does this fuse control all the power to the motor? Thanks again.
bgbass.1
some are the glass fuse some plug in and yes if its blown you wont get any power. its probably glass. mike
JUSTINTIME
check battery connection also
hogsnapper
bgbass,
thanks again, it was the 20 amp glass fuse that was blown. got it all fixed now. Thanks for the help.
