wow it finally sprang to life after 22 years in the barn, but I still think it's running hot. Cooling tube is one half inch from edge of prop, and I am not convinced water is making it up the tube. The tube is clear, I used some tubing any the water faucet to run water up the tube, and it ran back out the exhaust as well as the grid of exhaust holes. When running there is no sign of moisture coming out with the exhaust, and it's way to hot to hold your hand in front of for more than a couple of seconds. My only guess is that the tube should be closer to the prop edge, that's why I am after the measurement. Thanks in advance.
