HELP Need PART, HELP
jeromemorse
I took out my lower unit and found that the upper roller bearing was bad, i have ordered it from a local boat repair shop but they cant find a replacement gear that goes at the bottom of the drive shaft. I have looked it up on line and you can only buy the whole set and not just the small pinion gear. I have an Evinrude F40ELCO, g1014084. Any help!!!!
If anyone has a spare kicking around or used as a paper weight plz plz plz let me know....... I'm running out of ideas..
Thanks,
Jerry
drewpster
Re: HELP Need PART, HELP
Is the pinion gear damaged? If it is, the ring gear is likely damaged as well, right?
jeromemorse
No just the pinion gear, the upper roller bearings fell down into the lower chamber and got chewed up in the gear case by the forward gear and the pinion gear. The forward gear has some little chips out of it but overall is still in great condition. I just need the pinion gear.
Thanks,
Jerry
Ayuh,... They're sold as a Matched Set for a reason,.... You Need Both...
JB
Jerry: Please do not SHOUT!, Please do not double post. Both are very rude.
jeromemorse
oops, my bad. Did not know this. I have seen several posts that was the same in several forums here. But I will refrain from doing it. Again sorry.
Just trying to get one little gear for my little old motor....Put Put Put...
Jerry...
tashasdaddy
Salvage yards.
sea-way.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
Superior Marine (800-338-9281)
