help need to build a engine cover
betayv
hello guys 1987 seara 230 5.7 I need to build a engine cover for it any ideas?, thanks.
sphelps
Do you have the old one that you can use for a template ? Pics of the area would make it easier for the crew to help ya with idea's ..
Chad Flaugher
Yep, that's how I did mine. Use your old one for a template. If you can't do that, get ya some treated 1/2" plywood, and a treated 2x4" or 2x6". Rip your lumber into 2x2" material for cleats. Next, measure the width of your exhaust manifolds, and the length from stern just past your water pump pulley. Cut your plywood into those dimensions. (give yourself a little room to play) Attach a cleat UNDER your plywood on the stern side. This will be where your hinge mounts. Now it's time to build your sides. make sure everything you attach to the top goes underneath it. Use your cleat material mounted 1/2" inside your top, and attach your sides to the cleats. Here is mine. It's an exact duplicate of the original right down to 1/8". As you can see, it's not overbuilt in the factory. That's why everything needs to be mounted under the top, and not to the side. Assume people will be sitting on it in choppy waters. Mine has flared sides, and some funky angles. S quare would be much easier than this. Next comes foam, and marine grade vinyl. Might even foam (without vinyl) the inside for noise reduction.
