Help! Need to buy a new hub!
mdoher1
Can anyone tell me which size hub I need to buy? Not sure what size spindle it is on trailer.. I was hoping to buy the hub before disassembling.
I have a 2000 Four Winns trailer with a 215 Sundowner on it. The wheels are definitely standard 5-lug 4.5" spacing.
It's a tandem axle trailer, and the boat weighs like 4000lbs.
Any help is much appreciated!
four winns 214
Re: Help! Need to buy a new hub!
I have a 2002 Four Winns tandem axle trailer. Its spindles are 1 1/16 - 1 3/8. The ONLY way to be sure is to remove the hub you're replacing and check.
robert graham
Take the wheel/hub to Northern Tool or Tractor Supply or similar and match it up...they'll help you get it right!
mdoher1
Problem solved. I pulled off the hub and I had a tapered spindle. Put a Vortex hub on there... All Set... Next problem gimbal bearing...
